BT.com
Wishlist
Plustek SmartOffice PS456U
£530.74
£530.74
Add to wishlist
Delivery
Standard 1-3 working days
The Plustek SmartOffice PS 456U is a 80-page per minute, duplex color document scanner that is not only fast, it's reliable and cost effective. Ultrasonic misfeed detection ensures all of your critical documents are imaged correctly. Robust paper handling, advanced image processing and a high daily duty cycle all add up to the perfect departmental scanning solution for document management, content management and forms processing applications.
Plustek SmartOffice PS456U - document scanner
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Dual CCD
Max Supported Document Size
244 x 356 mm
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
80 ppm (mono) / 80 ppm (colour)
Max Document Size
244 mm x 2530 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
100 sheets
Duty Cycle
6000 scans per day
Microsoft Windows 2000/XP/Vista/7, Windows 8
31.87 cm x 23.07 cm x 22.83 cm
2.7 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
244 x 356 mm
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
Dual CCD
Max Document Scan Speed B/W
80 ppm
Max Document Scan Speed Colour
80 ppm
Duty Cycle
6000 scans per day
Scanner Speed Details
30 ppm - portrait (front) / colour (back) - A4 - 300 dpi , 60 ipm - portrait (front) / colour (back) - A4 - 300 dpi , 45 ppm - portrait (front) / colour (back) - A4 - 200 dpi , 90 ipm - portrait (front) / colour (back) - A4 - 200 dpi , 80 ppm - portrait (front) / greyscale (back) - A4 - 300 dpi , 160 ipm - portrait (front) / greyscale (back) - A4 - 300 dpi , 80 ppm - portrait (front) / black & white (back) - A4 - 300 dpi , 160 ipm - portrait (front) / black & white (back) - A4 - 300 dpi
Scanner Features
Ultrasonic Double Feed Detection
TWAIN, ISIS
Media Handling
Max Document Size
244 mm x 2530 mm
Automatic
100 sheets
USB 2.0
External power adapter
Software Included
Plustek DocAction, HotCard BizCard Finder 3.0, ABBYY FineReader 9.0 Sprint, Plustek DI Express 6
System Requirements Details
Pentium 4 - 2 GHz - RAM 1 GB - HD 800 MB
31.87 cm
23.07 cm
22.83 cm
2.7 kg
Scroll to top
