BT.com
Wishlist
Plustek SmartOffice PS406U
£402.76
Hurry, only 2 left in stock!
£402.76
Add to wishlist
Delivery
Standard 1-3 working days
Let's begin! You may find the SmartOffice PS406U is the right solution for your scanning needs. Enhanced with innovative features, it offers outstanding price/performance value in a compact footprint, conserving both space and budget. You get fast scanning speeds, a high daily duty cycle and robust paper handling capabilities, all from a compact, desktop scanner. You may feel this scanner delivers solutions for a multitude of imaging applications. Whatever you may involve such as document management, archiving, workflow or forms processing, watch this video of the SmartOffice PS406U that scans both sides of documents, in color in just a few seconds.
Plustek SmartOffice PS406U - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
CCD
Max Supported Document Size
244 x 356 mm
United Kingdom
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
40 ppm (mono) / 40 ppm (colour)
Max Document Size
244 mm x 356 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
100 sheets
Duty Cycle
4000 scans per day
Microsoft Windows 2000/XP/Vista/7
Microsoft Certification
Compatible with Windows 7
31.9 cm x 23.1 cm x 22.8 cm
2.7 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
244 x 356 mm
United Kingdom
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
CCD
Max Document Scan Speed B/W
40 ppm
Max Document Scan Speed Colour
40 ppm
Control Panel Buttons Functions
Scan-to-PDF
Duty Cycle
4000 scans per day
Scanner Speed Details
40 ppm - portrait (front) / colour (back) - A4 - 200 dpi , 80 ipm - portrait (front) / colour (back) - A4 - 200 dpi , 40 ppm - portrait (front) / greyscale (back) - A4 - 300 dpi , 80 ipm - portrait (front) / greyscale (back) - A4 - 300 dpi , 40 ppm - portrait (front) / black & white (back) - A4 - 300 dpi , 80 ipm - portrait (front) / black & white (back) - A4 - 300 dpi
Scanner Features
Ultrasonic Double Feed Detection
TWAIN
Media Handling
Max Document Size
244 mm x 356 mm
Automatic
100 sheets
USB 2.0
Automatic document feeder, calibration card
1 x USB cable
ENERGY STAR Certified
External power adapter
Software Included
Plustek DI Capture, Plustek DocAction, NewSoft Presto! PageManager 7.10, HotCard BizCard Finder 3.0, ABBYY FineReader 9.0 Sprint
System Requirements Details
Pentium 4 - 2 GHz - RAM 1 GB - HD 800 MB
31.9 cm
23.1 cm
22.8 cm
2.7 kg
Scroll to top
