BT.com
Wishlist
Plustek SmartOffice PS286 Plus
£320.02
11 in stock
£320.02
Add to wishlist
Delivery
Standard 1-3 working days
The Plustek SmartOffice PS286 Plus workgroup class document scanner is designed with the image quality, paper handling and reliability required by the most demanding business users but at a price point attractive to home and SOHO users. The small size and footprint of the SmartOffice PS286 Plus make it appropriate for office, front desk or portable scanning tasks.
This scanner is built to scan documents in any application requiring frequent document and rigid card scanning. The SmartOffice PS286 Plus is designed to scan business documents up to 14" long and rigid cards. Mixed batches of documents can be scanned without sorting thanks to the class leading paper handling and image processing.
Plustek SmartOffice PS286 Plus - document scanner
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Contact Image Sensor (CIS)
Additional Functions
Email, scan to print, scan to network share
Max Supported Document Size
220 x 356 mm
United Kingdom
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
600 dpi x 600 dpi
Max Document Scan Speed
25 ppm (mono) / 8 ppm (colour)
Max Document Size
220 mm x 356 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
1500 scans per day
Microsoft Windows 2000/XP/Vista/7
Microsoft Certification
Compatible with Windows 7
26.3 cm x 12.8 cm x 14.8 cm
1.7 kg
Interface Type
USB 2.0
220 x 356 mm
United Kingdom
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
Max Document Scan Speed B/W
25 ppm
Max Document Scan Speed Colour
8 ppm
Control Panel Buttons Functions
Scan, copy, email, file, PDF/OCR
Duty Cycle
1500 scans per day
Scanner Speed Details
8 ppm - colour - A4 - 200 dpi , 25 ppm - greyscale - A4 - 200 dpi , 25 ppm - black & white - A4 - 200 dpi , 50 ipm - duplex - greyscale - A4 - 200 dpi , 50 ipm - duplex - black & white - A4 - 200 dpi , 8 ipm - duplex - colour - A4 - 200 dpi
TWAIN
Media Handling
Max Document Size
220 mm x 356 mm
Automatic
50 sheets
USB 2.0 - Type B
Calibration card
1 x USB cable
FCC Class B certified
External power adapter
Power Consumption Operational (Standby)
18 Watt ( 0.5 Watt )
Software Included
ABBYY FineReader 6.0 Sprint Plus, Plustek DI Capture, Plustek DocAction, NewSoft Presto! PageManager 7.10, Plustek BizCard Finder 3.0
System Requirements Details
Pentium III - 1 GHz - RAM 256 MB - HD 800 MB
26.3 cm
12.8 cm
14.8 cm
1.7 kg
5 °C
20 - 80% (non-condensing)
Scroll to top
