BT.com
Wishlist
Plustek SmartOffice PL1500
£251.08
£251.08
Add to wishlist
Delivery
Standard Due date unavailable
SmartOffice PL1500 ADF document scanner, a new member of Smart Office series, offers high-speed scanning capability and compact design, making it a perfect solution for workgroups and other decentralized scanning applications.
SmartOffice PL1500 ADF scanner provides a maximum scanning speed of 15 pages per minute with optical resolution up to 1200 dpi. Auto Document Feeder (ADF) permits identify of large quantities of documents that holds up to 50 pages at one time.
Apart from ADF, it can be used as regular flatbed scanners which add even more versatility to satisfy all your needs. This SmartOffice PL1500 ADF scanner is a truly versatile document scanner that puts up outstanding value and high performance. It is well suited for business processes, corporate and SOHO use to achieve the highest level of productivity.
SmartOffice PL1500 ADF is idealistic for departmental or workgroup users, such as hospitals, law firms, CPA firms, banks and other financial institutions. This total solution document scanner is designed to provide maximum utility with minimum effort.
Plustek SmartOffice PL1500 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
CCD
Light Source
Xe-gas cold cathode fluorescent lamp
Max Supported Document Size
220 x 356 mm
United Kingdom
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
15 ppm (mono) / 8 ppm (colour)
Max Document Size
216 mm x 356 mm
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
1500 scans per day
AC 120/230 V
Microsoft Windows 2000/XP/Vista/7
Microsoft Certification
Compatible with Windows 7
46.8 cm x 34.7 cm x 17.5 cm
4.8 kg
Interface Type
USB 2.0
220 x 356 mm
United Kingdom
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
1200 dpi x 1200 dpi
Scan Element Type
CCD
Bulb / Light Source Type
Max Document Scan Speed B/W
15 ppm
Max Document Scan Speed Colour
8 ppm
Control Panel Buttons Functions
Scan, copy, file, OCR, Custom
Duty Cycle
1500 scans per day
Scanner Speed Details
8 ppm - colour - A4 - 200 dpi , 15 ppm greyscale (back) - A4 - 200 dpi , 15 ppm - black & white - A4 - 200 dpi
TWAIN
Media Handling
Max Document Size
216 mm x 356 mm
Plain paper
Supported Document Size Details
ADF - up to 220 x 356 mm , Flatbed - up to 216 x 297 mm
Automatic
50 sheets
USB 2.0 - Type B
Automatic document feeder
1 x USB cable
FCC Class B certified, RoHS, WEEE
External power adapter
AC 120/230 V
Software Included
ABBYY FineReader 6.0 Sprint Plus, Plustek DI Capture, Plustek DocAction, NewSoft Presto! PageManager 7.10
System Requirements Details
Pentium 4 - 2 GHz - RAM 512 MB - HD 800 MB
46.8 cm
34.7 cm
17.5 cm
4.8 kg
Scroll to top
