BT.com
Wishlist
Plustek PL7000 Document Scanner
Delivery
Standard Due date unavailable
The PL7000 provides you the fastest and most efficient software for your documents management. The PL7000 is a new member of Smart Office series, offering the high-speed scanning capability and compact design for workgroups and other decentralized scanning applications. The PL7000 is a versatile high-speed scanner for personal or business users looking to increase their efficiency while on a limited budget. It has a built-in Auto Document Feeder (ADF) that holds up to 80 pages at a time while providing a maximum scanning speed of 70 pages per minute, optical resolution up to 600 dpi, and features USB 2.0 compatibility. Fully automated buttons on front panel - Scans a stack of pictures, files them, saves in your preferred format, and at the dpi you want.
An extension to the popular Smart Office line, the PL7000 breaks the "speed barrier" by delivering up the high speed of self-fed document scanning. Ideal for small office/home office (SOHO) users or the heavy corporate user (such as hospitals, law firms, CPA firms, banks and other financial institutions) this new document scanner is designed to provide maximum utility with minimum effort.
Plustek SmartOffice PL7000 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
CCD
Max Supported Document Size
216 x 355.6 mm
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi
Max Document Scan Speed
70 ppm (mono)
Max Document Size
216 mm x 355.6 mm
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
80 sheets
Microsoft Windows XP Professional SP1, Microsoft Windows XP Home Edition SP1, Microsoft Windows 2000 SP4
Microsoft Certification
Certified for Windows Vista
5.5 kg
Interface Type
USB 2.0
216 x 355.6 mm
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi
Scan Mode
Single-pass
Scan Element Type
CCD
Max Document Scan Speed B/W
70 ppm
Scanner Speed Details
70 ppm - greyscale - A4 - 200 dpi
TWAIN
Media Handling
Max Document Size
216 mm x 355.6 mm
Plain paper
Automatic
80 sheets
USB 2.0 - Type B
1 x USB cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
UL, TUV GS, C-Tick, cUL, CB, FCC
External power adapter
Software Included
Drivers & Utilities, Presto! PageManager, Presto! ImageFolio, Readiris Pro 10 Corporate Edition
Additional Requirements
CD-ROM, USB port
System Requirements Details
Pentium III - 1 GHz - RAM 256 MB - HD 800 MB
5.5 kg
Scroll to top
