BT.com
Wishlist
Plustek Opticslim OF120
£1,565.29
£1,565.29
Add to wishlist
Delivery
Standard 1-3 working days
The OpticFilm 120 delivers the professional image quality results from 35 mm film strips, slides, and 120/220 film from 6 x 4.5 cm up to 6 x 12 cm in sizes. It is designed for professional photographers, advanced amateur photographers, film photo enthusiasts, photography schools and clubs. The OpticFilm 120 satisfies the film scanning requirements of advanced amateurs or professionals that require the ultimate in image quality and an ICC profiled scanning system.
Plustek OpticFilm 120 - film scanner - desktop - USB 2.0
Film scanner - desktop
Interface Type
USB 2.0
Scan Element Type
CCD
Light Source
LED
Max Supported Document Size
Film 120 (6 cm)
United Kingdom
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Optical Resolution
5300 dpi
Max Document Size
60 mm x 120 mm
Supported Document Type
Slides, film
Apple MacOS X 10.6, Apple MacOS X 10.5, Apple MacOS X 10.7 Lion, Microsoft Windows Vista / XP / 7 / 8, Apple MacOS X 10.8
21 cm x 37.4 cm x 18.9 cm
5.7 kg
Interface Type
USB 2.0
Film 120 (6 cm)
United Kingdom
Scanner
Input Type
Grayscale Depth
Colour Depth
48-bit colour
Optical Resolution
5300 dpi
Scan Element Type
CCD
Bulb / Light Source Type
LED
Scan Density Range
4.01D
Media Handling
Max Document Size
60 mm x 120 mm
Slides, film
USB 2.0
Software Included
SilverFast Ai Studio 8
System Requirements Details
2 GHz - RAM 2 GB - HD 10 GB
21 cm
37.4 cm
18.9 cm
5.7 kg
Scroll to top
