BT.com
Wishlist
Plustek OpticPro A320 Flatbed Scanner
Plustek OpticPro A320 Flatbed...
£449.22
£449.22
Add to wishlist
Delivery
Standard 1-3 working days
Plustek OpticPro A320 takes the pain out of large format scanning. It is USB 2.0 scanning device that can scan an A3 size document with high quality - resolution as high as 1600 dpi and scanning area as large as 12" x 17" (304.8 mm x 431.8 mm) - in just 11.2 seconds. Often, large format scanning is considered to be complex but Plustek OpticPro A320 makes is very easy for the end-user with its seven one-touch function buttons. What's more, it comes bundled with highly effective image processing and document management software for enhanced versatility. It provides for fast and secure PDF conversion, highly accurate optical character recognition (OCR) and easy sharing of files over a network.
Plustek OpticPro A320 has been specially designed for professionals who require best of both worlds - high quality results coupled with efficiency. It is ideal for graphic designers, publishing companies, libraries, schools, small office/home office (SOHO) users and for those who require to do large format scanning regularly like hospitals, law firms, financial institutions etc.
Plustek OpticPro A320 - flatbed scanner
Flatbed scanner - desktop
Interface Type
USB 2.0
Scan Element Type
CCD
Light Source
Xe-gas cold cathode fluorescent lamp
Max Supported Document Size
304.8 x 431.8 mm
United Kingdom
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
1600 dpi x 1600 dpi
Scan Speed
8.5 scan / sec
Max Document Size
304.8 mm x 431.8 mm
Document Feeder Type
Manual
Microsoft Windows 2000/XP/Vista/7
Microsoft Certification
Compatible with Windows 7
62.3 cm x 40 cm x 13 cm
7.5 kg
Interface Type
USB 2.0
304.8 x 431.8 mm
United Kingdom
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
1600 dpi x 1600 dpi
Scan Mode
Single-pass
Scan Element Type
CCD
Bulb / Light Source Type
Scan Speed
8.5 scan / sec
Scanner Speed Details
8.5 sec/scan - colour - A3 - 300 dpi
TWAIN
Media Handling
Max Document Size
304.8 mm x 431.8 mm
Manual
USB 2.0
1 x USB cable
C-Tick, BSMI, CB, FCC, C-ETL, ETL
External power adapter
Power Consumption Operational (Standby)
36 Watt ( 4 Watt )
Software Included
ABBYY FineReader 6.0 Sprint Plus, NewSoft MaxReader, Plustek DI Capture, Plustek DocAction, NewSoft Presto! ImageFolio 4.5, NewSoft Presto! PageManager 7.10
System Requirements Details
Pentium 4 - 2 GHz - RAM 512 MB - HD 800 MB
62.3 cm
40 cm
13 cm
7.5 kg
Scroll to top
