BT.com
Wishlist
Plustek OpticBook4800
£483.20
£483.20
Add to wishlist
Delivery
Standard 1-3 working days
OpticBook 4800 has provided you a non-destructive book scanning solution. Special book edge design with LED light source of the solution, not only gives the perfect book scanned images, but also creates a lot of energy saving. Once digitized, the books can be unraveled into single pages or be reduced further, into snippets of a page. These snippets will be remixed into reordered books and virtual bookshelves.
OpticBook 4800 also creates crisp sharp images of the pages, which can then be made into different formats. It has been bundled with highly effective image processing, fast and secure searchable PDF conversion.
OpticBook 4800 not only is designed for corporations, universities, libraries, governmental agencies and schools but also an ideal product for the consumers who practice a green concept in their life, by creating a paper less work place or living environment!
Plustek OpticBook 4800 - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scan Element Type
CCD
Light Source
LED
Max Supported Document Size
216 x 297 mm
United Kingdom
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
1200 dpi
Scan Speed
3.6 sec / scan
Max Document Size
216 mm x 297 mm
Supported Document Type
Plain paper, bulk objects (such as books, magazines and other bound materials)
Duty Cycle
2500 scans per day
AC 120/230 V
Microsoft Windows 2000/XP/Vista/7
Microsoft Certification
Compatible with Windows 7
49.1 cm x 29.1 cm x 10.2 cm
3.45 kg
Interface Type
USB 2.0
216 x 297 mm
United Kingdom
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
1200 dpi
Scan Element Type
CCD
Bulb / Light Source Type
LED
Scan Speed
3.6 sec / scan
Duty Cycle
2500 scans per day
TWAIN
Media Handling
Max Document Size
216 mm x 297 mm
USB 2.0
RoHS, WEEE
External power adapter
AC 120/230 V
Power Consumption Operational (Standby)
18 Watt
Software Included
Presto! ImageFolio, Presto! PageManager 7.0, Plustek DI Capture, Plustek Book Pavilion, Plustek DI Express
System Requirements Details
Pentium 4 - 2 GHz - RAM 512 MB - HD 800 MB
49.1 cm
29.1 cm
10.2 cm
3.45 kg
Scroll to top
