BT.com
Wishlist
Plustek MobileOffice D412
£198.80
19 in stock
£198.80
Add to wishlist
Delivery
Standard 1-3 working days
The MobileOffice D412's is a color, duplex, sheet fed document and card scanner capable of scanning an 8.5 x 11.7" page in 4.6 seconds. The compact design and flexible dual power configuration enables the scanner to be used in the office or with your laptop on the road.
High scan speed, small footprint, 1000 page per day duty cycle and reliable design of the MobileOffice D412 make it perfect for commercial applications that require scanning of rigid cards such as IDs and documents. Applications such as: patient registration, lockbox, remote deposit, bank teller, loan processing, home healthcare, nurses carts, ID verification are a perfect match for the MobileOffice D412.
The MobileOffice D412 also features advanced image processing that allows you to scan mixed sized documents and embossed plastic cards with no adjustments. Images are automatically straightened, rotated and adjusted for exposure with no manual intervention. The result is more accurate Optical Character Recognition (OCR) and fewer pages that need to be rescanned.
Plustek MobileOffice D412 - sheetfed scanner - portable - USB 2.0
Sheetfed scanner - portable
Interface Type
USB 2.0
Scan Element Type
Contact Image Sensor (CIS)
Max Supported Document Size
216 x 356 mm
United Kingdom
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Size
216 mm x 356 mm
Supported Document Type
Plain paper, card scanner, plastic card
Document Feeder Type
Manual
Duty Cycle
1000 scans per day
Microsoft Windows 2000/XP/Vista/7
Microsoft Certification
Compatible with Windows 7
29.5 cm x 6.9 cm x 5 cm
0.77 kg
Interface Type
USB 2.0
216 x 356 mm
United Kingdom
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single/duplex pass
Scan Element Type
Control Panel Buttons Functions
Scan, Scan-to-PDF
Duty Cycle
1000 scans per day
Scanner Speed Details
4.6 sec/scan - greyscale - A4 - 300 dpi , 5.2 sec/scan - duplex - greyscale - A4 - 300 dpi
Scanner Features
Powered by USB port
TWAIN
Media Handling
Max Document Size
216 mm x 356 mm
Manual
USB 2.0
External power adapter
Software Included
Plustek DI Capture, Plustek DocAction, NewSoft Presto! PageManager 7.10, HotCard BizCard Finder 3.0, ABBYY FineReader 9.0 Sprint, Plustek DocTWAIN, Plustek DI Express 6
System Requirements Details
Pentium 4 - 2 GHz - RAM 512 MB - HD 800 MB
29.5 cm
6.9 cm
5 cm
0.77 kg
Scroll to top
