BT.com
Wishlist
Plextor 128GB PX-128M6M mSATA 6GB/s Solid State Drive
Delivery
Standard Due date unavailable
The Plextor M6M is a high-performance mSATA 6 Gb/s SSD specifically engineered to give ultrabook, tablet PC, and other JEDEC MO-300 form factor users the speed and low power consumption benefits of the newest generation SSD technology.
Plextor M6M PX-128M6M - solid state drive - 128 GB - SATA 6Gb/s
Solid state drive - internal
128 GB
Hardware Encryption
mSATA
SATA 6Gb/s
Data Transfer Rate
600 MBps
Native Command Queuing (NCQ), TRIM support, hardware encryption, Plextor True Speed technology , S.M.A.R.T., 256-bit AES, JEDEC MO-300
29.8 mm x 50.8 mm x 3.6 mm
10 g
3 years warranty
128 GB
Hardware Encryption
mSATA
SATA 6Gb/s
29.8 mm
50.8 mm
3.6 mm
10 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
520 MBps (read) / 340 MBps (write)
4KB Random Read
90000 IOPS
4KB Random Write
76000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 52 pin mini-SATA
Compatible Bay
mSATA
Apple MacOS, Linux, Microsoft Windows
UL, TUV, VCCI, C-Tick, BSMI, CB, FCC, RoHS, KCC
Limited warranty - 3 years
70 °C
Shock Tolerance
1500 g @ 1ms
Vibration Tolerance
2.17 g @ 7-800 Hz (non-operating)
Scroll to top
