BT.com
Wishlist
Plantronics Y Cable - Training Cord with Microphone Mute & Quick Disconnect
Plantronics Y Cable - Training Cord...
£21.73
More than 50 in stock
£21.73
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
For Plantronics A22, E10, M12, P10, S20 CA40, P10, P10H
Ideal for listening in to calls for training and coaching purposes, this Adapter Trainer Cord with Microphone Mute Switch and Quick Disconnect Clamp will allow for supervised calls for maximum effectiveness. (4 pin Quick Disconnect/QD only)
Plantronics' mission is to enhance personal communication. By allowing you to be more productive, safe, and comfortable you'll notice a marked improvment in the clarity of your daily communications.
Plantronics Y Adapter Trainer - headset splitter
Cable
Headset splitter
Connector
Quick Disconnect
Connector (Second End)
2 x Quick Disconnect
Avaya M12LU/CM, M12LUCM; Plantronics A22, E10, M12, M22, MX10, P10, S20; Headset Switcher MX10; P10 Series P10H
Cable Type
Headset splitter
Connector
Quick Disconnect
Avaya M12LU/CM, M12LUCM , Plantronics A22, E10, M12, M22, MX10, P10, S20 , Plantronics Headset Switcher MX10 , Plantronics P10 Series P10H
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Item is new, the packaging is damaged.
Ref: 4RQG 034546
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£6.02
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
