BT.com
Wishlist
Plantronics U10 Bottom Cable for Cisco & IP Telephones
Plantronics U10 Bottom Cable for...
£11.07
More than 50 in stock
£11.07
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Plantronics is a world's leading designer, manufacturer and marketer of lightweight communications headset products. The company also produces products for the computer and mobile market segments, specialty telephone products, such as amplified telephone headsets, telephones for hearing-impaired users and noise-canceling headsets and handsets for use in high-noise environments. Plantronics knows that an audio device such as a headset is nothing without the proper connection to the receiver or the transmitter. So Plantronics offers a wide range of cabling solutions to provide reliable connection to your equipment and to give you the clearest, noise-free sound possible.
Plantronics headset amplifier cable - 3 m
Cable
Headset amplifier cable
Length
3 m
Connector
Quick Disconnect
Connector (Second End)
Headset amplifier modular plug
Coiled
DuoPro; DuoSet; Encore; EncorePro; FreeHand; Mirage; StarSet; Supra; SupraPlus; SupraPlus SL; TriStar
Cable Type
Length
3 m
Coiled
Connector
Quick Disconnect
Plantronics DuoPro , Plantronics DuoSet , Plantronics Encore , Plantronics EncorePro , Plantronics FreeHand , Plantronics Mirage , Plantronics StarSet , Plantronics Supra , Plantronics SupraPlus , Plantronics SupraPlus SL , Plantronics TriStar
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been opened but is in excellent condition
Ref: 8KM7 035287
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£4.20
Ref: 8KM7 035288
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£4.20
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
