BT.com
Wishlist
Plantronics Savor M1100 - Headset - wireless - Bluetooth 2.1 EDR
Delivery
Standard Due date unavailable
Raise the power of your voice
The Plantronics M1100 headset is your smartphone assistant. Now your voice takes control to answer a call without lifting a finger. Or use the dedicated voice button to connect, pair and check status. Go beyond conversations and indulge your ears with streaming music or podcasts. You'll hear and be heard with rich clarity thanks to the triple-microphone precision and Plantronics signature audio quality. This is hands-free on a whole new level.
With Plantronics® Vocalyst™, you can let your voice do the work. Think of Vocalyst as an assistant built into your M1100 headset. When you want to do something and you need to be hands free, simply call Vocalyst using voice commands, say what you want to do and it gets done. You can respond and listen to your emails, have your SMS read aloud, record reminders and even update your Facebook status all by using your voice. You can customise your M1100 Vocalyst package, even down to the language you wish to use.
Key features
Three microphones deliver superior sound quality
AudioIQ³ and DSP reduce background noise
Convenient voice commands to control your headset
A2DP for streaming music, podcasts and more
Whispered voice alerts for low battery and more
Dedicated on/off switch preserves battery power
iPhone headset battery meter
Flexible silicone ear gel tips
Easy to put on to quickly answer calls
Lightweight and comfortable design
Battery provides up to 4 hours talk time / 7 days standby
Weighs only 9 grams
Plantronics Savor M1100 - headset
Headset - Bluetooth - wireless
Recommended Use
Portable electronics
Headphones Form Factor
Ear-bud
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 2.1 EDR
Sound Output Mode
Mono
Microphone
Built-in
Controls
Mute, volume, on/off, answer/end
1 year warranty
Telekom move
Headset - Bluetooth
9 g
Recommended Use
Headphones
Ear-bud
Wireless
Wireless Technology
Bluetooth
Available Microphone
Bluetooth Version
Bluetooth 2.1 EDR
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP)
Sound Output Mode
Mono
Remote Control
Controls
Connector Type
USB
3 gel ear tips
Power adapter - external
AC 120/230 V
Headset battery rechargeable - lithium polymer
Run Time (Up To)
4 hour(s)
Standby Time
168 hours
Limited warranty - 1 year
Telekom move
Scroll to top
