Click to visit BT.com
BT.com
Wishlist
Plantronics Marque 2 M165 - Wireless, Bluetooth 3.0 Headset - White
Quicklinx: 8M5MWS00
Mfr#: 88130-05
The perfect companion for your smartphone
The Plantronics® Marque 2™, a perfect companion for smartphones, now features DeepSleep™ power-saving mode and dual microphones that reduce noise and wind for clear, crisp call quality. For added convenience, there's even a dual charger for simultaneously charging your headset and phone from either your computer or car. Simply check the on-screen battery meter on your iPhone or Android™ smartphone. You can also listen to music or stream audio and Internet radio, and you can manage your calls without pressing buttons - just say "Answer" or "Ignore".
Bluetooth 3.0
Dual microphones for improved noise and wind noise reduction
DSP and echo noise reduction
Multipoint technology
Voice alerts for connection, battery life and volume
Answer/ignore voice recognition
DeepSleep mode allows up to 180 days (6 months) of battery life
Universal fit ear gel
Wideband audio support
Headset battery meter for iPhone and iPad
2-in-1 car charger also charges smartphone
Listen to music, GPS, and more
On-screen headset battery meter
Plantronics Marque 2 M165 - headset
Headset - wireless - Bluetooth
Recommended Use
Portable electronics
Middle East, Africa, Europe
White
Headphones Form Factor
Ear-bud - over-the-ear mount
Wireless - Bluetooth
Bluetooth Version
Bluetooth 3.0
Sound Output Mode
Mono
Microphone
Built-in
Controls
Volume
Headset - Bluetooth
7 g
White
Recommended Use
Headphones
Available Microphone
Bluetooth Version
Bluetooth 3.0
Bluetooth Profiles
Hands Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP)
Sound Output Mode
Mono
Headphones Ear Pads
Included
Remote Control
Controls
Volume
Connector Type
USB
USB cable
3 ear tips
Headset battery rechargeable
Run Time (Up To)
7 hour(s)
Standby Time
264 hours
