BT.com
Wishlist
Plantronics GameCom X40 Gaming Headset - Xbox 360
Delivery
Standard Due date unavailable
Plantronics Gamecom X40
Unleash the hidden power of your Xbox 360 with a headset that immerses you in stereo sound
Play games, listen to music and watch movies with the Plantronics GameCom X40, a comfortable stereo headset for the Xbox 360. The concealed mic-boom hides into the headband and out of your way. Specially designed earpods redistribute the pressure for long wearing comfort.
Unleash the hidden power of your Xbox 360® with the Gamecom® X40™ headset which immerses you in rich stereo sound. The 40mm speakers ensure you get the very best sound from your Xbox. Specially designed cushioned ear pods and headband, provide a great fit allowing you to play games, listen to music and watch movies in comfort for longer. The concealed microphone-boom easily tucks into the headband and stays hidden until you're ready to use it. Independent voice and audio controls located on the earpods allow you to stay focused on the game.
Gain An Immersive Audio Experience
  • 40 mm speakers let you get the best sound from your Xbox
  • Communicate clearly with the adjustable microphone
  • Tuck the microphone away when not in use
  • Stay comfortable during long sessions with the specially designed earpods
  • Adjust voice and audio volumes, using on-ear controls
  • Play in style, thanks to a sleek, modern, close-ear design
Plantronics GameCom X40 - headset
Headset - wired
Recommended Use
Game console
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Microphone
Boom
Controls
Mute, volume
2 years warranty
Xbox 360, Xbox 360 S
Headset
Recommended Use
Game console
Headphones
Circumaural
Wired
Available Microphone
Sound Output Mode
Stereo
Diaphragm
40 mm
Microphone
Boom
Remote Control
Controls
Mute, volume
Connector Type
3 x headset , USB ( 4 PIN USB Type A )
2 x headset cable
Scroll to top
