Click to visit BT.com
BT.com
Wishlist
Plantronics GameCom X30 Gaming Headset - Xbox 360
Quicklinx: 7PB1WS00
Mfr#: 72483-15
Industrial strength headset designed for comfort and clear communications
Shift Xbox into overdrive with the ultimate-quality GameCom X30 headset for Xbox 360.
You smashed your opponents. You delivered the innocent. You showed a rare form of courage you never knew you had. But now that bunch of know-it-all, bench-warming trash talkers you call "friends" are ripping on your mission. It's time to rock the armchair warriors with the bitter taste of retribution...
Shift Xbox into overdrive with the single ear, corded GameCom® X30™ headset. This ultra-light, must-have Xbox accessory boasts a supple, ear-fitting design, perfect for all-night gaming. Convenient inline volume and mute controls put you in the driver's seat, while the single in-ear design leaves one ear connected to the `real world'. The flexible boom picks up your every word, and the noise-cancelling microphone delivers an incredibly crisp audio experience. Play and chat in comfort with this ergonomic shake-proof design, which will be the envy of all.
Engaged, Yet Alert, The Single-Ear Headset for Xbox 360
Get Comfortable, This Could Take a While:
- Communicate clearly with other players with the noise-canceling microphone
- Repositionable microphone for crisp communication
- Ergonomic design and shake-proof fit
- Adjust the volume and mute the microphone, using the convenient inline controls
- Industrial-strength construction
- Use with your Xbox 360® or Xbox (requires Xbox Communicator, not included)
Plantronics GameCom X30 - headset
Headset - wired
Recommended Use
Game console
Headphones Form Factor
Under-the-ear
Wired
Sound Output Mode
Mono
Microphone
Boom
Controls
Mute, volume
2 years warranty
Xbox 360, Xbox 360 S
Headset
Recommended Use
Game console
Headphones
Under-the-ear
Wired
Available Microphone
Sound Output Mode
Mono
In-Cord Volume Control
Microphone
Boom
Remote Control
Controls
Mute, volume
Connector Type
Headset
Headset cable
2 years warranty
Service & Support Details
