BT.com
Wishlist
Plantronics BackBeat GO 2 Wireless Bluetooth Headset Black with Charging Case
Plantronics BackBeat GO 2 Wireless...
£69.99
For the Gym, For The Commute and With Charging Case!
27 in stock
£69.99
Add to wishlist
Delivery
Standard 3-5 working days
Plantronics BackBeat® GO 2 wireless earbuds deliver immersive audio for your non-stop life, so you can lose the cord, free your music, and still take that call. Designed to seal in the bass and block out the noise, you'll quickly lose yourself in the soundtrack of your day. Whether you're working out or swaying to the beat, the military-grade moisture resistance protects against sweat or a coffee spill. If you tuck it away and forget to turn it off, the DeepSleep™ hibernation mode keeps earbuds charged and ready to use for up to six months.
Unleash your music and GO.
Quick Info
  • Immersive, high-fidelity audio
  • Sweat-proof, durable design
  • Stable, comfortable fit
  • DeepSleep™ power-saving mode
  • Up to 4.5 hours of listening time
  • Digital noise reduction for clear calls
  • Inline controls for calls and music
  • Onscreen battery meter
  • 2-in-1 USB charging cable for earbuds and smartphone
Details
  • Earbuds seal in the crisp highs, natural mid-tones, and rich bass so you hear every nuance.
  • Military-grade moisture resistance and rugged, tangle-free cable won't let you down.
  • Multiple fit options secure earbuds for active use and all day wearing.
  • DeepSleep™ mode puts earbuds into hibernation when away from phone, extending battery readiness up to six months.
  • Enjoy your favourite music or movie with up to 4.5 hours of listen time.
  • Inline controls make it easy to take calls, skip tracks, and adjust volume.
  • Bluetooth® technology lets you connect to smartphones or tablets for music, videos, and calls.
  • Headset battery meter automatically shows onscreen for iPhone and iPad.
  • Plantronics Battery Meter widget enables a headset battery meter on Android™ 3.0 tablets, and Android 4.0 phones and tablets (download from Google Play).
  • Charge your earbuds and phone simultaneously with the 2-in-1 USB charging cable
Whether You're Out and About...
Or Working Out!
Scroll to top
