BT.com
Wishlist
Plantronics Backbeat Fit Black Silver Wireless Headset
Plantronics Backbeat Fit Black...
£74.00
More than 50 in stock
£74.00
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
It's time to get moving and get Fit. Whatever your workout, the flexible, sweat-proof Plantronics BackBeat Fit wireless stereo headphones keep pace with you. Its powerful audio lets you clearly hear your music while its safety-oriented design lets you hear your surroundings and be seen at night. The reversible armband secures your smartphone while you're moving and stores your headphones when you're done - making it your perfect workout partner.
Engineered for sport
Ready to go the extra mileā€”or ten? Flexible and durable, BackBeat FIT pushes you further, withstanding the rain or a rinse under the tap with a waterproof design that meets the IP57 rating and an additional sweat-proof nano-coating. And whether you wear them running on a road or on a trail, the open ear tip design lets you hear the sounds around you.
It stays in place when you don't
When it comes to your workout, nothing gets in your way. Stay focused and distraction-free with wireless sport headphones that stay comfortably in place. BackBeat FIT provides superior stability with a behind-the-ear design and comfortable ear tip. The only reminder that you're wearing them is the rich sound of your favourite playlist or podcast pushing you to your next personal best.
As unstoppable as you are
You never quit. Neither should your headphones. With up to eight hours of listening from a single charge, BackBeat FIT helps you power through a full week of workouts. Subtle voice alerts let you know how much listening time you have left, and the 15-minute quick charge provides an hour of play to get you through the day's challenge.
Plantronics Backbeat Fit - headset
Headset - wireless - Bluetooth
Recommended Use
Portable electronics, phone
Headphones Form Factor
In-ear - behind-the-neck mount
Wireless - Bluetooth
Bluetooth Version
Bluetooth 3.0
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 50 - 20000 Hz - Sensitivity 105 dB/mW
Controls
Answer/end, play/pause, next/previous track
Headset - Bluetooth
24 g
Recommended Use
Protection
Waterproof
Headphones
Available Microphone
Bluetooth Version
Bluetooth 3.0
Bluetooth Profiles
Hands Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Frequency Response
50 - 20000 Hz
Total Harmonic Distortion (THD)
3%
Sensitivity
105 dB/mW
Diaphragm
13 mm
Magnet Material
Neodymium
Remote Control
Controls
Wireless Link
Transmission Range
10 m
Connector Type
USB ( 5 pin Micro-USB Type B (power only) )
Micro-USB charge cable
Carrying case, armband case
Headset battery rechargeable - lithium polymer
Run Time (Up To)
8 hour(s)
Standby Time
336 hours
Recharge Time
2 hour(s)
Scroll to top
