BT.com
Wishlist
Philips V-Line 273P3LPHES 27" LCD Monitor 1920x1080 VGA DVI 3xUSB 2.0 HDMI
Delivery
Standard Due date unavailable
Eco-friendly, EPEAT Gold certified Philips professional 273P3 LED display with intelligent PowerSensor detects user presence and adjusts power consumption saving up to 80% of energy bills!
Philips Brilliance P-line 273P3LPHES - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
55 kWh
Power Consumption (On mode)
38 W
USB 2.0 hub
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1200:1 / 20000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Silver
64.2 cm x 24.4 cm x 52.8 cm
8.74 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, WEEE, halogen-free
3 years warranty
Display Type
Energy Class
Class B
55 kWh
38 W
Diagonal Size
27"
Built-in Devices
USB 2.0 hub
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
170
Backlight Technology
WLED
Controls & Adjustments
Volume
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
Sync on Green, sRGB colour management, HDCP, Eco-Mode, PowerSensor, SmartResponse, SmartImage, Touch Control
Silver
64.2 cm x 24.4 cm x 52.8 cm - with stand
8.74 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D , 3 x USB 2.0 downstream , Audio line-in , Headphones , USB 2.0 upstream (Type B) , HDMI
Mechanical
Tilt Angle
25
Swivel Angle
130
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
MTBF
30,000 hour(s)
Power Supply
Internal
20.4 Watt
Power Consumption Stand by / Sleep
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 64.2 cm - depth: 24.4 cm - height: 52.8 cm - weight: 8.74 kg , Without stand - width: 64.2 cm - depth: 6.5 cm - height: 39.1 cm - weight: 6.38 kg
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.75
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.32
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£21.09
£14.71
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£28.29
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£19.30
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.30
£59.58
Scroll to top
