BT.com
Wishlist
Philips Philips 241B7QUPBEB/00 24 INCH IPS VGA DP HDMI USB
Philips Philips 241B7QUPBEB/00 24...
£259.99
35 in stock
£259.99
Add to wishlist
Delivery
Standard 1-3 working days
Simple USB-C connection and crystal-clear IPS images. The Philips B-line monitor with USB-C connector allows simple notebook docking via one cable for fast data and video to full HD IPS display, and even notebook charging.
Philips B Line 241B7QUPBEB - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
24 W
USB 3.0/USB-C hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort, USB-C
Display Position Adjustments
Textured black
54.1 cm x 25.7 cm x 52.7 cm
5.72 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, VCCI, ICES-003, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, TCO Certified Edge, EPA, cETLus, RCM, CU-EAC
Display Type
Energy Class
Class A
35 kWh
24 W
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 3.0/USB-C hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, PowerSensor, SmartResponse, SmartContrast, SmartImage, Smart Ergo base, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Ultra Narrow Border, Mercury free, USB 3.0 Quick Charge, Wide Viewing Angle, EasyRead
Textured black
54.1 cm x 25.7 cm x 52.7 cm - with stand
5.72 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DisplayPort , HDMI , USB-C upstream , DisplayPort output , Audio line-in , Headphones , Network , 2 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+30
Swivel Angle
350
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x USB-C cable , 1 x USB-C to USB-A cable , 1 x audio cable
MTBF
70,000 hour(s)
15.4 Watt
Power Consumption Stand by
0.7 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
Included Software
Philips SmartControl
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10
Dimensions & Weight Details
With stand - width: 54.1 cm - depth: 25.7 cm - height: 52.7 cm - weight: 5.72 kg , Without stand - width: 54.1 cm - depth: 5.7 cm - height: 33.2 cm - weight: 3.29 kg
Shipping Width
60.3 cm
Shipping Depth
22.4 cm
Shipping Height
49.2 cm
Shipping Weight
8.94 kg
ENERGY STAR Certified
20 - 80%
Scroll to top
