BT.com
Wishlist
Philips Hue Wireless Lighting Dimmer Switch
Delivery
Standard Due date unavailable
Dim your Philips Hue lights
Using the Philips Hue switch, you can smoothly dim your favorite light setting up and down.
Place it anywhere
The Philips Hue Dimmer switch can be used as a normal wall switch. You can place it anywhere you want, using screws or the adhesive tape on the back plate of the switch.
No wires - battery-powered
The Philips Hue dimmer switch is battery-powered, so there is no installation required.
Use as a remote control
You can also use the Philips Hue dimmer switch as a remote control for your comfort.
Switch between scenes
When using your dimmer switch with Philips Hue white ambiance or Philips Hue white and color ambiance products, you can use the on-button to switch between 4 light recipes, or use the Philips Hue app to configure your favorite 4 scenes. It's all up to you.
What's in the box?
  • 1x Philips Hue Wireless Lighting Dimmer Switch
Philips Hue Dimmer - switch / dimmer
Switch / dimmer
Functions
Light control
Power Source
Wireless - ZigBee, 802.15.4
Frequency Band
2400 - 2483.5 Mhz
Europe
2 years warranty
3.5 cm x 1.1 cm x 9.2 cm
Switch / dimmer
Functions
Light control
Power Source
Wireless - ZigBee
Max Range Indoors
12 m
Frequency Band
2400 - 2483.5 Mhz
Europe
Battery Required
1 x CR2450
Warranty
2 years warranty
3.5 cm
1.1 cm
9.2 cm
67 g
-5 °C
45 °C
5 - 95% (non-condensing)
Scroll to top
