BT.com
Wishlist
Philips Hue Go White and Colour EU/UK
Philips Hue Go White and Colour...
£59.98
More than 50 in stock
£59.98
Add to wishlist
Delivery
Standard 3-5 working days
Portable Light
Light spaces in new, creative ways. Philips Hue go is the most versatile light in your home. When plugged into a power outlet, use it to color your walls with up to 16 million colors or bright white light. Detach it from the mains, and Philips Hue go becomes a portable centerpiece you can carry to set the mood and bring the best light for your activities. It is powered by a rechargeable internal battery that can last up to 3 hours. Also in portable mode, Philips Hue go can be fully controlled with your smart device. The built-in smart battery management guarantees maximum usage. Although Philips Hue go is not waterproof, it is designed to withstand high humidity. Play with light your way, limited only by your imagination.
Control Your Way
Control Philips Hue go conveniently and quickly even without your smart device at hand. Activate light settings directly by pressing the smart control on the product. Choose from 7 different light effects: functional warm white light, cool energizing daylight, and 5 natural dynamic light effects that match your special moments. The fun really starts when you connect Philips Hue go with the bridge and start discovering the endless possibilites. Control Philips Hue go from your smartphone or tablet via the Philips Hue app or any third party app developed for Philips Hue. Set timers, notifications, alarms, and sync to your entertainment system for the full Philips Hue experience. With online access, you can even control your lights from anywhere in the world.
Natural Dynamic Effects
Enhance special moments with living light. Philips Hue go has 5 patented natural dynamic effects: Cozy Candle, Sunday Coffee, Meditation, Enchanted Forest, and Night Adventure. Each dynamic effect has its own mix of colors to set the right mood.
Paint With Light
Use Philips Hue go to transform your room and paint your walls with 16 million colors. Or choose your favorite picture and relive the moment with splashes of light. You can save your favorite scenes and recall them whenever at the tap of a finger.
Sync Lights with Movies
Extend your TV viewing experience to the whole room or lift your gaming experience to the next level. Download the third party apps and discover the amazing things you can do with Philips Hue.
Sync Lights with Music
Sync light to your favorite music and enjoy every beat to the fullest. Transform any room into a dance floor and see how light reacts to your music. Download third party apps and get the party started with Philips Hue.
Create Your Ambiance
Set the right ambience for any moment with a range of beautiful, natural white light. Use the app to set any shade of white light, from cool energizing daylight to relaxing warm white light. So set the mood. Change the ambience. Feel different. Feel better.
Light for Your Well-being
Light influences our mood, behavior, alertness and routines. Through the app, you can set the light that is optimal for your moment. Philips Hue helps you to energize, concentrate, read and relax. Customize your daily routines into moments you can enjoy. Set the mood. Change the ambiance. Feel different. Feel better.
Wake-up
Ease your sleeping routine and wake up gently for a fresh start of each day. Philips Hue will help get you out of bed in a nice way. The gradually increasing light intensity gives you the feeling you are waking up naturally with sunlight - rather than the rude awakening of an alarm ringing.
Light Schedules for Home Automation
Philips Hue can make it seem like you're home when you're not, using the schedule function in the Philips Hue app. Set the lights to come on at a pre-set time, so the lights are on when you arrive home. You can even set rooms to light up at different times. And of course, you can let the lights turn off gradually in the night, so you never have to worry whether you've left any lights on
Away-from-home Control
You can control your lights remotely wherever you are. Check if you have forgotten to switch your lights off before you left your home, and switch them on if you are working late.
Connect your Philips Hue lights with the bridge and start discovering the endless possibilites.
Control your lights from your smartphone or tablet via the Philips Hue app, or add switches to your system to activate your lights. Set timers, notifications, alarms, and more for the full Philips Hue experience.
Experience guaranteed smooth dimming with Philips Hue. Not too bright. Not too dark. Just right. No need for wires, an electrician or installation.Hue Go is a portable light that lets you light any moment with white light, 16 million colours and natural dynamic effects. Set the mood via the on product control or connect it to the Hue bridge for extended features via your smart device
What's in the Box?
  • 1x Philips Hue Go
  • 1x Power Adapter
Scroll to top
