BT.com
Wishlist
Philips E-line 273E3QHSB 27" 1920x1080 6ms VGA DVI-D HDMI LED Monitor
Delivery
Standard Due date unavailable
Experience super high contrast images on this AMVA LED display. With a big size, wide viewing angle and bright, vivid pictures it is ready to entertain you.
Philips E-line 273E3QHSB - LED monitor - 27"
LED-backlit LCD monitor - 27"
Panel Type
A-MVA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
5000:1 / 20000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Internal
Display Position Adjustments
Tilt
64.2 cm x 22.7 cm x 44 cm
8.2 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE, TCO Displays 5.2
3 years warranty
Display Type
Diagonal Size
27"
Panel Type
A-MVA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Turkish
Sync on Green, sRGB colour management, HDCP, SmartImage Lite, SmartResponse, SmartContrast, Touch Control
64.2 cm x 22.7 cm x 44 cm - with stand
8.2 kg
Audio
Speakers - stereo - internal
Output Power / Channel
2 Watt
VGA ¦ DVI-D ¦ HDMI ¦ Headphones ¦ Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
Rotation Angle
90
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
MTBF
30,000 hour(s)
Power Supply
Internal
25.5 Watt
Power Consumption Stand by / Sleep
0.5 Watt
Included Software
Philips SmartControl Lite
Apple MacOS X, Microsoft Windows 7
Dimensions & Weight Details
With stand - width: 64.2 cm - depth: 22.7 cm - height: 44 cm - weight: 8.2 kg , Without stand - width: 64.2 cm - depth: 6.4 cm - height: 39.1 cm - weight: 6.5 kg
Limited warranty - 3 years
20 - 80%
Scroll to top
