BT.com
Wishlist
Philips E-line 273E3LHSB 27" LED Monitor - HDMI DVI-D VGA
Delivery
Standard Due date unavailable
This big 273E3 Full HD display with touch control is ready to engage you in the entertainment world. This display has a resolution that is referred to as Full HD. With state-of-the-art LCD screen technology it has the full high-definition widescreen resolution of 1920 x 1080p. It allows the best possible picture quality from any format of HD input signal. It produces brilliant flicker-free pictures with optimum brightness and superb colors. This vibrant and sharp image will provide you with an enhanced viewing experience.
SmartImage Lite is an exclusive, leading edge Philips technology that analyzes the content displayed on your screen. Based on a scenario you select, SmartImage Lite dynamically enhances the contrast, color saturation and sharpness of images and videos for ultimate display performance - all in real time with the press on a single button.
You want the LCD flat display with the highest contrast and most vibrant images. Philips advanced video processing combined with unique extreme dimming and backlight boosting technology results in vibrant images. SmartContrast will increase the contrast with excellent black level and accurate rendition of dark shades and colors. It gives a bright, lifelike picture with high contrast and vibrant colors.
Touch controls are intelligent, touch sensitive icons that replace protruding buttons that lets the user adjust the monitor to their requirement. Responding to your lightest touch, touch control gives the monitor a modern feel.
Philips easy picture format control on OSD is to switch from the 4:3 aspect ratio to the widescreen mode and back again to match the display's aspect ratio with your content for working with wide documents without scrolling or viewing widescreen media in the widescreen mode and distortion-free, native mode display of 4:3 ratio content.
Philips E-line 273E3LHSB - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
57 kWh
Power Consumption (On mode)
39 W
Stereo speakers
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1200:1 / 20000000:1 (dynamic)
Response Time
3.5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
64.2 cm x 22.7 cm x 44 cm
8.2 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, UL, TUV GS, BSMI, GOST, cUL, SEMKO, TUV Ergo, FCC, DDC/CI, RoHS, TCO Displays 5.1
3 years warranty
Display Type
Energy Class
Class B
57 kWh
39 W
Diagonal Size
27"
Built-in Devices
Stereo speakers
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
3.5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
170
Backlight Technology
WLED
Controls & Adjustments
Volume, input select
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Turkish
Sync on Green, sRGB colour management, HDCP, SmartImage Lite, SmartResponse, SmartContrast, Touch Control
64.2 cm x 22.7 cm x 44 cm - with stand
8.2 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D , HDMI , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
25
Flat Panel Mount Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
20.4 Watt
Power Consumption Stand by / Sleep
0.5 Watt
On / Off Switch
No
Included Software
Philips SmartControl Lite
Dimensions & Weight Details
With stand - width: 64.2 cm - depth: 22.7 cm - height: 44 cm - weight: 8.2 kg , Without stand - width: 64.2 cm - depth: 6.4 cm - height: 39.1 cm - weight: 6.5 kg
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
Accessories
£9.99
£6.94
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.78
£36.49
£49.42
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£56.07
Scroll to top
