BT.com
Wishlist
Philips E-Line 27" Full HD IPS Monitor VGA HDMI
Delivery
Standard Due date unavailable
Colours like you've never seen before. This brilliant wide-view Quad HD display with Ultra Wide-Color offers crisp images with the richest and most vivid colours on an elegant display for your best creations yet.
What's in the box
  • Monitor with stand
  • Cables
  • User Documentation
Philips E-line 276E8FJAB - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
70 kWh
Power Consumption (On mode)
46 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Black, gun metal
61.3 cm x 18.9 cm x 46.6 cm
4.69 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, DDC/CI, RoHS, Lead-Free, WEEE, CECP, EPA, TCO Displays, RCM, CU
Display Type
Energy Class
Class C
70 kWh
46 W
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Pixel Per Inch
109
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
46 - 75 Hz
Horizontal Refresh Rate
54 - 84 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, SmartImage Lite, SmartContrast, Flicker Free technology, 132% sRGB colour gamut, 114% NTSC colour gamut
Black, gun metal
61.3 cm x 18.9 cm x 46.6 cm - with stand
4.69 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
HDMI (HDCP) , DisplayPort , VGA , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
1 x VGA cable , 1 x HDMI cable , 1 x audio cable
MTBF
50,000 hour(s)
22.93 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Apple MacOS X, Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10
Dimensions & Weight Details
With stand - width: 61.3 cm - depth: 18.9 cm - height: 46.6 cm - weight: 4.69 kg , Without stand - width: 61.3 cm - depth: 4.1 cm - height: 37.4 cm - weight: 4.07 kg
ENERGY STAR Certified
20 - 80%
Scroll to top
