BT.com
Wishlist
Philips Clinical Review 27" LCD 1920x1200 DVI VGA Monitor - White
Delivery
Standard Due date unavailable
This Philips display is ideal for everyday clinical care environment. D-image preset gives you consistent DICOM grayscale medical images. Its medical grade power supply ensures basic safety. Anti-microbial housing inhibits bacterial growth.
Philips Brilliance C271P4QPJEW - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
51 kWh
Power Consumption (On mode)
35 W
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
5000:1
Response Time
12 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Textured white
63.9 cm x 19.1 cm x 57.7 cm
7.9 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, GOST, IEC 60601-1-2, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, DICOM Part 14, IEC 60601-1, TCO Displays 6.0
Display Type
Energy Class
Class B
51 kWh
35 W
Diagonal Size
27"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
5000:1
Colour Support
Response Time
12 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
HDCP, PowerSensor, Smart Ergo base, SmartImage Clinic, Clinical D-image
Textured white
63.9 cm x 19.1 cm x 57.7 cm - with stand
7.9 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DVI-D , VGA , DisplayPort , 4 x USB 2.0 , Headphones , Audio line-in , HDMI
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), antimicrobial finish
MTBF
30,000 hour(s)
Power Supply
External
26 Watt
Power Consumption Stand by
0.4 Watt
On / Off Switch
No
Included Software
Philips SmartControl Premium
Apple MacOS X, Microsoft Windows Vista / 7 / 8
Dimensions & Weight Details
With stand - width: 63.9 cm - depth: 19.1 cm - height: 57.7 cm - weight: 7.9 kg , Without stand - width: 63.9 cm - depth: 6.4 cm - height: 40.5 cm - weight: 5.1 kg
ENERGY STAR Certified
20 - 80%
Accessories
£9.99
£6.94
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.78
£36.49
£49.42
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£56.07
Scroll to top
