BT.com
Wishlist
Philips Clinical Review 24" LCD 1920x1200 DVI VGA Monitor - White
Delivery
Standard Due date unavailable
This Philips display is ideal for an everyday clinical care environment. D-image pre-set gives you consistent DICOM Grayscale medical images. Its medical-grade power supply ensures basic safety. Anti-microbial housing inhibits bacterial growth.
Philips Brilliance C240P4QPYEW - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A+
Energy Consumption per Year
25 kWh
Power Consumption (On mode)
17 W
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Full HD 1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
14 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
White
55.5 cm x 24.4 cm x 55 cm
6.97 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, GOST, TUV Ergo, RoHS, Lead-Free, WEEE, DICOM Part 14, IEC 60601-1, TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class A+
25 kWh
17 W
Diagonal Size
24"
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
14 ms
Vertical Refresh Rate
48 - 85 Hz
Horizontal Refresh Rate
24 - 94 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
PowerSensor, Smart Ergo base, SmartControl Premium, SmartImage Clinic, Clinical D-image
White
55.5 cm x 24.4 cm x 55 cm - with stand
6.97 kg
Audio
Speakers - stereo
Output Power / Channel
4 Watt
DVI-D , VGA , DisplayPort , 4 x USB 2.0 , Headphones , Audio line-in
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), antimicrobial finish
MTBF
30,000 hour(s)
Power Supply
External
Power Consumption Stand by
0.4 Watt
On / Off Switch
Apple MacOS X, Microsoft Windows Vista / 7 / 8
Dimensions & Weight Details
With stand - width: 55.5 cm - depth: 24.4 cm - height: 55 cm - weight: 6.97 kg , Without stand - width: 55.5 cm - depth: 6.5 cm - height: 38.8 cm - weight: 4.64 kg
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£40.57
£24.94
£9.80
£18.27
£14.01
Scroll to top
