BT.com
Wishlist
Philips C221S3UCW/00 22" 1920x1080 USB Monitor
Delivery
Standard Due date unavailable
This Philips USB monitor is ideal for usage in mobile clinical environment where AC power may not be conveniently accessible. Simply connect it with a single USB cable from your notebook to deliver video and power.
Philips C221S3UCW - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
150 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
USB
Display Position Adjustments
Height, swivel, tilt
Textured white
50.7 cm x 20.1 cm x 40.2 cm
3.85 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, RoHS, Lead-Free, WEEE, EN 60601-1-2, EN 60601-1
3 years warranty
Display Type
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
150 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
160
Vertical Viewing Angle
150
Backlight Technology
WLED
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
sRGB colour management, Smart Ergo base
Textured white
50.7 cm x 20.1 cm x 40.2 cm - with stand
3.85 kg
USB 2.0
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Height Adjustment
70 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), antibacterial
MTBF
30,000 hour(s)
Power Supply
Internal
10.3 Watt
Power Consumption Stand by
0.3 Watt
Apple MacOS X, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
Dimensions & Weight Details
With stand - width: 50.7 cm - depth: 20.1 cm - height: 40.2 cm - weight: 3.85 kg , Without stand - width: 50.7 cm - depth: 5.9 cm - height: 32.3 cm - weight: 3.44 kg
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
Scroll to top
