BT.com
Wishlist
Philips Brilliance P-Line 24" 1920x1080 6ms VGA DVI-D LED Monitor
Delivery
Standard Due date unavailable
The Philips LED display with webcam helps you collaborate and communicate, saving your time and money.
Philips Brilliance P-line 241P4QPYKES - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Stereo speakers, USB Hub, 2.0 megapixel camera
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
5000:1 / 20000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Black, silver
56.5 cm x 22 cm x 51.8 cm
6.4 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, TCO Certified Edge, TCO Displays 5.2
3 years warranty
Display Type
Diagonal Size
24"
Built-in Devices
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
Sync on Green, sRGB colour management, HDCP, Lead-free, Eco-Mode, PowerSensor, SmartContrast, SmartImage
Black, silver
56.5 cm x 22 cm x 51.8 cm - with stand
6.4 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
VGA , DVI-D , 3 x USB 2.0 , Audio line-in , Headphones , DisplayPort
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
23.4 Watt
Power Consumption Stand by / Sleep
0.1 Watt
Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
Dimensions & Weight Details
With stand - width: 56.5 cm - depth: 22 cm - height: 51.8 cm - weight: 6.4 kg , Without stand - width: 56.5 cm - depth: 5.5 cm - height: 35.2 cm - weight: 4.2 kg
ENERGY STAR Certified
Limited warranty - 3 years
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£40.57
£24.94
£9.80
£18.27
£14.01
Scroll to top
