BT.com
Wishlist
Philips Brilliance B-Line 23" 1920x1080 5ms VGA DVI-D LED Monitor
Delivery
Standard Due date unavailable
The Philips PowerSensor LED display using 65% post consumer recycled plastics and PVC, BFR free housing is ideal for eco-friendly productivity.
Philips Brilliance B-line 231B4LPYCS - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Stereo speakers
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Black, silver
54.7 cm x 22.7 cm x 50.7 cm
4.89 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, TCO Displays 5.0
3 years warranty
Display Type
Diagonal Size
23"
Built-in Devices
Stereo speakers
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
Sync on Green, sRGB colour management, HDCP, PowerSensor, SmartContrast, SmartImage
Black, silver
54.7 cm x 22.7 cm x 50.7 cm - with stand
4.89 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
VGA , DVI-D , Audio line-in/out , 2 x USB 2.0 , DisplayPort
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
100 mm
Flat Panel Mount Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
24.2 Watt
Power Consumption Stand by / Sleep
0.1 Watt
Included Software
Philips SmartControl Premium
Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
Dimensions & Weight Details
With stand - width: 54.7 cm - depth: 22.7 cm - height: 50.7 cm - weight: 4.89 kg , Without stand - width: 54.7 cm - depth: 6 cm - height: 34.3 cm - weight: 3.07 kg
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.63
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.13
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£19.78
£13.83
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.90
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£18.24
Scroll to top
