BT.com
Wishlist
Philips Brilliance B-line 220B4LPYCB 22" 1680x1050 5ms VGA DVI-D DisplayPort LED Monitor
Delivery
Standard 1-3 working days
The Philips PowerSensor LED display using 65% post consumer recycled plastics and PVC, BFR free housing is ideal for eco-friendly productivity.
Philips Brilliance B-line 220B4LPYCB - LED monitor - 22"
LED-backlit LCD monitor - 22"
USB Hub
Aspect Ratio
16:10
Native Resolution
1680 x 1050 at 60 Hz
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Textured black with black stand
50.4 cm x 22.7 cm x 50.9 cm
5.2 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, TCO Certified Edge, TCO Displays 5.2
3 years warranty
Display Type
Diagonal Size
22"
Built-in Devices
USB Hub
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
Sync on Green, sRGB colour management, HDCP, PowerSensor, SmartContrast, SmartImage, Smart Ergo base
50.4 cm x 22.7 cm x 50.9 cm - with stand
5.2 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
VGA , DVI-D (HDCP) , Audio line-in , 2 x USB 2.0 , Headphones , DisplayPort
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
16.8 Watt
Power Consumption Stand by / Sleep
0.1 Watt
Apple MacOS X, Microsoft Windows Vista / XP / 7
Dimensions & Weight Details
With stand - width: 50.4 cm - depth: 22.7 cm - height: 50.9 cm - weight: 5.2 kg , Without stand - width: 50.4 cm - depth: 5.9 cm - height: 34.9 cm - weight: 3.38 kg
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
Scroll to top
