BT.com
Wishlist
Philips Brilliance 272C4QPJKAB - 27" - 2560 x 1440 6MS 2xHDMI DVI-D speakers LED Monitor
Clearance
Last Few Remaining
Price Drop
Price Drop!
Delivery
Standard 1-3 working days
This Philips 27" display will amaze you with its Crystalclear Quad HD 2560 x 1440 images and brilliant colors. MultiView allows active dual connect and view. Its 2-magepixel webcam enables you to socialize.
Philips Brilliance 272C4QPJKAB - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
62 kWh
Power Consumption (On mode)
42 W
2.0 megapixel camera
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.233 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
12 ms (typical); 6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, DisplayPort
Speakers
Integrated
Display Position Adjustments
Tilt
Textured black with black stand
63.9 cm x 19.7 cm x 49.5 cm
6.3 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class B
62 kWh
42 W
Diagonal Size
27"
Built-in Devices
Panel Type
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Brightness
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
Picture in picture, picture by picture, Sync on Green, sRGB colour management, PowerSensor, SmartResponse, MultiView, Crystal Clear, SmartContrast, SmartImage, SmartKolor, SmartTxt
63.9 cm x 19.7 cm x 49.5 cm - with stand
6.3 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DVI-D (dual link) (HDCP) , Audio line-in , Headphones , DisplayPort , 2 x HDMI
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
38 Watt
Power Consumption Stand by
0.4 Watt
On / Off Switch
Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 63.9 cm - depth: 19.7 cm - height: 49.5 cm - weight: 6.3 kg , Without stand - width: 63.9 cm - depth: 6.4 cm - height: 40.5 cm - weight: 5.6 kg
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
Scroll to top
