BT.com
Wishlist
Philips Brilliance 242G5DJEB 24" 1920x1080 1ms VGA DVI-D HDMI DisplayPort LED Monitor
Delivery
Standard Due date unavailable
This advanced Philips gaming display redraws the screen upto 144 times per second for ultra smooth, brilliant images. SmartFrame helps you highlight specific screen area. Special gaming pre-sets and remote smart keypad keeps you in control.
Philips Brilliance 242G5DJEB - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
48 kWh
Power Consumption (On mode)
33 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.277 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
5 ms (typical); 1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Textured black
56.5 cm x 22 cm x 51.7 cm
6.27 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SASO, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE, TCO Certified Edge
3 years warranty
Display Type
Energy Class
Class B
48 kWh
33 W
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.277 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 120 Hz
Horizontal Refresh Rate
30 - 140 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Russian, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, HDCP, SmartResponse, SmartContrast, Mobile High-Definition Link (MHL), Smart Frame, SmartConnect, SmartImage Game, SmartLeypad
Textured black
56.5 cm x 22 cm x 51.7 cm - with stand
6.27 kg
DVI-D (dual link) , VGA , DisplayPort , 2 x HDMI (HDCP) , 4 x USB 3.0
Mechanical
Tilt Angle
25
Swivel Angle
130
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
18.58 Watt
Power Consumption Stand by
0.5 Watt
Apple MacOS X, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 56.5 cm - depth: 22 cm - height: 51.7 cm - weight: 6.27 kg , Without stand - width: 56.5 cm - depth: 6.3 cm - height: 35.4 cm - weight: 4.13 kg
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
Accessories
£9.99
£6.91
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.84
£36.18
£49.00
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.62
Scroll to top
