BT.com
Wishlist
Philips Brilliance 231C5TJKFU 23" 1920x1080 5ms VGA HDMI DisplayPort Multi-Touch IPS LED Monitor
Delivery
Standard Due date unavailable
Get engaged with Philips SmoothTouch display. Groovy touch gestures like tap, grab, pinch, rotate, zoom, swipe brings your apps to life. Interactive touch games get more exciting. Now you can explore the world with 10 fingertips!
Philips Brilliance 231C5TJKFU - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23" - touchscreen
Energy Class
Class A
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
22 W
1.0 megapixel camera
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
14 ms (typical); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Tilt
Cool grey, high glossy cool grey, textured cool grey
56.3 cm x 7.2 cm x 40.6 cm
5.16 kg
Plug and Play, FCC Class B certified, BSMI, GOST, SASO, SEMKO, RoHS, Lead-Free, ISO 9241-307, WEEE
3 years warranty
Display Type
Energy Class
Class A
31 kWh
22 W
Diagonal Size
23"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartResponse, SmartImage, Mobile High-Definition Link (MHL), SmartConnect, smart stand
56.3 cm x 7.2 cm x 40.6 cm - with stand
5.16 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
Input
Touchscreen
2 x HDMI , DisplayPort , 2 x USB 3.0
Mechanical
Tilt
MTBF
30,000 hour(s)
Power Supply
External
26.27 Watt
Power Consumption Stand by
0.5 Watt
Apple MacOS X, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 56.3 cm - depth: 7.2 cm - height: 40.6 cm - weight: 5.16 kg , Without stand - width: 56.3 cm - depth: 4.5 cm - height: 37 cm - weight: 4.8 kg
Limited warranty - 3 years
20 - 80%
Accessories
£9.99
£6.87
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.73
£35.97
£48.72
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.27
Scroll to top
