BT.com
Wishlist
Philips BDM3490UC/00 34" 3440x1440 VGA HDMI Curved Monitor
Delivery
Standard 1-3 working days
Inspired by the world around us. The gentle curve of the Philips Brilliance Curved UltraWide display puts you at the center of the desktop, for a truly immersive experience like never before.
Philips Brilliance BDM3490UC - LED monitor - curved - 34.1"
LED-backlit LCD monitor - 34.1"
Energy Class
Class C
Energy Consumption per Year
94 kWh
Power Consumption (On mode)
65 W
Curved Screen
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
QHD 3440 x 1440 at 60 Hz
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
14 ms (grey-to-grey), 5 ms (grey-to-grey with overdrive)
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, HDMI (MHL), DisplayPort
Display Position Adjustments
Tilt
Textured glossy black/grey with white back cover
82.6 cm x 22 cm x 47.9 cm
10.28 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, ICES-003, SASO, SEMKO, DDC/CI, RoHS, ISO 9241-307, WEEE, TCO Certified Edge, E-Standby, KUCAS, CECP, EPA, cETLus, RCM
Display Type
Energy Class
Class C
94 kWh
65 W
Diagonal Size
34.1"
Curved Screen
Built-in Devices
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
30 - 160 Hz
Horizontal Refresh Rate
30 - 99 kHz
Horizontal Viewing Angle
172
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Picture in picture, picture by picture, Sync on Green, sRGB colour management, Lead-free, MultiView, SmartImage, edge-to-edge glass, 99% sRGB colour gamut, BFR/PVC-free, Mercury free, DTS Sound
82.6 cm x 22 cm x 47.9 cm - with stand
10.28 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
2 x HDMI , MHL / HDMI , DisplayPort , 4 x USB 3.0 , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
MTBF
70,000 hour(s)
41 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1
Dimensions & Weight Details
With stand - width: 82.6 cm - depth: 22 cm - height: 47.9 cm - weight: 10.28 kg , Without stand - width: 82.6 cm - depth: 8.8 cm - height: 38.3 cm - weight: 7.77 kg
ENERGY STAR Certified
20 - 80%
Scroll to top
