BT.com
Wishlist
Philips BDM3470UP/00 34" 3440x1440 VGA DVI HDMI Monitor
Delivery
Standard Due date unavailable
Expand your experience with this 34" UltraWide Philips display. See the big picture with all the details with this large UltraWide screen. Multitask like never before with multiple features at once.
Philips BDM3470UP - LED monitor - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class C
Energy Consumption per Year
92 kWh
Power Consumption (On mode)
63 W
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
QHD 3440 x 1440
Pixel Pitch
0.232 mm
Brightness
320 cd/m²
Contrast Ratio
1000:1 / 40000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Input Connectors
HDMI, DVI, DisplayPort, VGA
Speakers
Internal
Display Position Adjustments
82.8 cm x 27 cm x 62.7 cm
9.46 kg
Environmental Standards
ENERGY STAR Qualified
TCO Certified Edge, TCO Displays 6.0, EPA 6.0
Display Type
Energy Class
Class C
92 kWh
63 W
Diagonal Size
34"
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
QHD 3440 x 1440
Pixel Pitch
0.232 mm
Brightness
320 cd/m²
Contrast Ratio
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
SmartResponse, MultiView, SmartContrast, Mobile High-Definition Link (MHL)
82.8 cm x 27 cm x 62.7 cm - with stand
9.46 kg
Audio
Speakers - internal
VGA , DVI , HDMI , DisplayPort , 2 x USB 2.0 , 2 x USB 3.0 , Audio line-in , Headphones
Mechanical
Height Adjustment
180 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x audio cable
Power Supply
Internal
40.8 Watt
Power Consumption Stand by
0.4 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
Included Software
Philips SmartControl Premium
Dimensions & Weight Details
With stand - width: 82.8 cm - depth: 27 cm - height: 62.7 cm - weight: 9.46 kg , Without stand - width: 82.8 cm - depth: 5.8 cm - height: 37.8 cm
ENERGY STAR Certified
Accessories
£8.85
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£39.98
£24.58
£9.80
£18.00
£13.78
Scroll to top
