BT.com
Wishlist
Philips BDL6526QT 65" 1920x1080 8ms VGA DVI HDMI DP USB LED LFD
Philips BDL6526QT 65" 1920x1080 8ms...
£2,515.68
£2,515.68
Add to wishlist
Delivery
Standard Due date unavailable
Get even closer to your audience than ever before. Fast, precise and extremely durable, its high performance is matched by excellent reliability and functionality
Philips Signage Solutions BDL6526QT 65" Class (64.5" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
65"
Diagonal Size
64.5 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/60i, 480/60p, 1080/50i, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
1 ports
LAN
PC Interface
VGA (HD-15)
AMVA
LCD Backlight Technology
WLED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
Pixel Shift
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class A
250 Watt
Power Consumption (On mode)
130 W
Energy Consumption per Year
190 kWh
155.4 cm x 11 cm x 92.9 cm
65.6 kg
3 years warranty
Energy Class
Class A
250 Watt
130 W
190 kWh
Diagonal Class
65"
Diagonal Size
64.5 in
Commercial Use
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
Modes
Portrait mode
Pixel Shift
Dimensions
Without stand
155.4 cm
11 cm
92.9 cm
65.6 kg
Display
LCD Display Technology
AMVA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Coating
Anti-glare
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
4000:1
Brightness
360 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.74 x 0.74mm
Pull Down Compensation
3:2, 2:2
Touchpoints Qty
6
Response Time
8 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish
Comb Filter
3D digital
Dynamic Contrast, 3D MA deinterlacing, Multitouch, Smart Insert, Optical Touch technology, Open Pluggable Specification slot, Smart Control, Motion Compensation
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800, 1600 x 900
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Connector Type
HDMI , VGA input , S-Video input , Audio line-in , VGA output , DVI-D input , Component video input , Composite video input , Composite video output , Audio line-in , Audio line-out , Speakers output , Network , Serial , USB
Batteries, carrying handle
VGA cable , Serial cable , USB cable
FCC Class B certified, UL, C-Tick, cUL, SASO, CB, CCC, RoHS, Lead-Free, EMF, KUCAS, EPA, EAC
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
On / Off Switch
Smart power
Limited warranty - 3 years
Dimensions & Weight Details
Panel without stand - 155.4 cm x 11 cm x 92.9 cm x 65.6 kg
5 °C
20 - 80%
Accessories
£7.05
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£20.13
£37.29
£50.50
Scroll to top
