BT.com
Wishlist
Philips BDL6520EL 65" 1920x1080 6.5ms VGA DVI HDMI DP USB LED LFD
Philips BDL6520EL 65" 1920x1080...
£1,551.52
£1,551.52
Add to wishlist
Delivery
Standard Due date unavailable
Maximizing your content delivery whilst lowering your TCO has never been so easy, this 65" display offers breathtaking HD picture quality with lower power consumption.
Philips Signage Solutions E-Line BDL6520EL 65" Class (64.5" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
65"
Diagonal Size
64.5 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 1080i, 1080p, 480i, 576i, 576p
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
250 Watt
155 cm x 9.3 cm x 92.7 cm
52 kg
3 years warranty
250 Watt
Diagonal Class
65"
Diagonal Size
64.5 in
Commercial Use
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
155 cm
9.3 cm
92.7 cm
52 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
4000:1
Brightness
360 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.74 x 0.74mm
Pull Down Compensation
3:2, 2:2
Response Time
8 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish
Backlight Life
50,000 hour(s)
Comb Filter
3D digital
Dynamic Contrast, Smart Insert
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
2 x speakers output , HDMI , VGA input , DVI-D input , Component video input , 2 x audio line-in , Composite video input , S-Video input , Serial input , Network , Serial output
VGA cable
FCC Class B certified, UL, GOST, cUL, CCC, RoHS
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Smart power
Limited warranty - 3 years
Accessories
£7.63
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£21.84
£41.94
£56.80
Scroll to top
