BT.com
Wishlist
Philips BDL5588XL 55" 1920x1080 12ms VGA DVI HDMI DP LED LFD
Philips BDL5588XL 55" 1920x1080...
£2,654.11
£2,654.11
Add to wishlist
Delivery
Standard Due date unavailable
Impress your audience with the most impact full video wall. With ultra narrow bezel and stunning picture quality, you are sure to create the most memorable visual experience.
Philips Signage Solutions BDL5588XL 55" Class (54.6" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Diagonal Size
54.6 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Video Wall Components Qty
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
IPS
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
Advanced Colour Calibration
Speaker System
2 speakers
Remote Control
Standard remote
110 Watt
121.34 cm x 10.335 cm x 68.42 cm
29.2 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
110 Watt
Diagonal Class
55"
Diagonal Size
54.6 in
Commercial Use
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
2 ports
PC Interface
Modes
Portrait mode, landscape mode
Design
Ultra Narrow Bezel Concept
100
Dimensions
Without stand
121.34 cm
10.335 cm
68.42 cm
29.2 kg
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Colour Depth
Up to 1.07 million colours
Image Contrast Ratio
1400:1
Dynamic Contrast Ratio
500000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.63 x 0.63mm
Pull Down Compensation
3:2, 2:2
Response Time
12 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
Backlight Life
50,000 hour(s)
Comb Filter
3D digital
Dynamic Contrast, 3D MA deinterlacing, Smart Control
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - built-in - 10 Watt
Connector Type
Component video input , Composite video input , DVI-D input , 2 x HDMI , DisplayPort input , DisplayPort output , DVI-I , Audio line-in , Audio line-in , Remote control input , Remote control input , Network , Serial input , Serial output , Speakers output , VGA input , Audio line-out
VGA cable , Serial cable
FCC Class B certified, UL, GOST, cUL, CB
ENERGY STAR Version
6.0
Power supply
Power Consumption Stand by
0.5 Watt
Smart power
Limited warranty - 3 years
20 - 80%
Accessories
£7.63
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£21.84
£41.94
£56.80
Scroll to top
