BT.com
Wishlist
Philips BDL5560EL 55" 1920x1080 12ms VGA DVI HDMI DP USB LED LFD
Delivery
Standard Due date unavailable
With this energy-efficient Signage Solution display, you will enjoy all the benefits of state-of- the-art connectivity and content management possibilities while being assured that remote management safeguards low cost of ownership.
Philips Signage Solutions E-Line BDL5560EL 55" Class ( 54.6" viewable ) LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Diagonal Size
54.6 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Video Wall Components Qty
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Digital signage
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
AC 100/230 V ( 50/60 Hz )
122.52 Watt
124.44 cm x 6.9 cm x 71.52 cm
30.6 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
122.52 Watt
Diagonal Class
55"
Diagonal Size
54.6 in
Commercial Use
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
100
Dimensions
Without stand
124.44 cm
6.9 cm
71.52 cm
30.6 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
1300:1
Dynamic Contrast Ratio
500000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.21 x 0.63mm
Pull Down Compensation
3:2, 2:2
Response Time
12 ms
Backlight Life
60,000 hour(s)
Comb Filter
3D digital
Commercial Features
Digital signage
Dynamic Contrast, 3D MA deinterlacing, Smart Insert, SmartCMS
Stands & Mounts
Flat Panel Mount Interface
100 x 100 mm, 100 x 200 mm, 200 x 200 mm, 400 x 200 mm, 400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Media Player
Supported Video Formats
MPEG-4, WMV, MKV, VOB, TS, M2TS, M4V, MTS
Supported Audio Formats
MP3, WMA, WAV, AAC, AIFF, LPCM, M4A
Supported Pictures Formats
BMP, JPG, GIF
USB Port
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
DisplayPort input , 2 x HDMI input , DVI-D input , VGA input , USB , Component video input , Composite video input , DisplayPort output , DVI-I , VGA output , Audio line-in , Audio line-in , Audio line-out , Speakers output , Network , Serial , Remote control
VGA cable
FCC Class B certified, UL, VCCI, C-Tick, BSMI, GOST, cUL, CB, CCC, RoHS, PSE Mark, J-MOSS
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.4 Watt
Smart power
Limited warranty - 3 years
20 - 60%
Accessories
£7.63
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£21.84
£41.94
£56.80
Scroll to top
