BT.com
Wishlist
Philips BDL5556ET 55" 1920x1080 12ms VGA DVI HDMI DP LED LFD
Philips BDL5556ET 55" 1920x1080...
£2,498.13
£2,498.13
Add to wishlist
Delivery
Standard Due date unavailable
Discover a high level of interaction with this multi touch LED display. Get even closer to your audience than ever before. Fast, precise and extremely durable, its high performance is matched by excellent reliability and functionality.
Philips BDL5556ET 55" Class (54.6" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Diagonal Size
54.6 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class B
140 Watt
Power Consumption (On mode)
131 W
Energy Consumption per Year
192 kWh
125.73 cm x 7.9 cm x 72.81 cm
43 kg
3 years warranty
Energy Class
Class B
140 Watt
131 W
192 kWh
Diagonal Class
55"
Diagonal Size
54.6 in
Commercial Use
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
Protection
Tempered glass protection
Dimensions
Without stand
125.73 cm
7.9 cm
72.81 cm
43 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Coating
Anti-glare
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
1300:1
Dynamic Contrast Ratio
500000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.63 x 0.63mm
Pull Down Compensation
3:2, 2:2
Touchpoints Qty
6
Response Time
12 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
Backlight Life
50,000 hour(s)
Comb Filter
3D digital
Dynamic Contrast, 3D MA deinterlacing, Multitouch, Open Pluggable Specification slot, Smart Control
Stands & Mounts
Flat Panel Mount Interface
100 x 100 mm, 100 x 200 mm, 200 x 200 mm, 400 x 200 mm, 400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Connector Type
HDMI input , VGA input , DVI-D input , Component video input , VGA output , Composite video input , DVI-I , Audio line-out , Audio line-out , Network , DisplayPort input , Serial , USB , Audio line-in , Speakers output
VGA cable , Serial cable , USB cable
Plug and Play, FCC Class B certified, UL, C-Tick, cUL, SASO, CB, CCC, RoHS, EMF, KUCAS, EPA, EAC
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
On / Off Switch
Smart power
Limited warranty - 3 years
5 °C
20 - 80%
Accessories
£7.63
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£21.84
£41.94
£56.80
Scroll to top
