BT.com
Wishlist
Philips BDL4330QL 43" 1920x1080 6.5ms VGA DVI HDMI LED LFD
Philips BDL4330QL 43" 1920x1080...
£612.70
11 in stock
£612.70
Add to wishlist
Delivery
Standard 1-3 working days
Deliver startlingly clear images in a more eco-friendly way. High on performance and reliability, yet low on power consumption, it is ideal for projects where no compromise is accepted.
Philips Signage Solutions Q-Line BDL4330QL Q-Line - 43" Class (42.5" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
43"
Diagonal Size
42.5 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Video Wall Components Qty
225
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
LAN
PC Interface
DVI, VGA (HD-15)
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
HTML5 support, Clinical D-image
Picture Enhancements
Pixel Shift
Speaker System
2 speakers
DVR
Flash - 8 GB
USB
Remote Control
Standard remote
Voltage
AC 120/230 V
87 Watt
96.82 cm x 5.99 cm x 55.94 cm
8.7 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
87 Watt
Diagonal Class
43"
Diagonal Size
42.5 in
Commercial Use
Series
Q-Line
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
Pixel Shift
Timer Functions
Wake, power on delay
225
Dimensions
Without stand
96.82 cm
5.99 cm
55.94 cm
8.7 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
3000:1
Dynamic Contrast Ratio
50000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.49 x 0.49mm
Response Time
6.5 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish
Backlight Life
50,000 hour(s)
Commercial Features
Smart Control, SmartCMS, One Wire, Smart Collection
Stands & Mounts
Flat Panel Mount Interface
200 x 200 mm, 400 x 400 mm
DVR
DVR
Flash - 8 GB
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Media Player
Supported Video Formats
MPEG-4, Xvid, DivX, WMV, ASF, QuickTime, AVI, MKV, MOV, VOB, FLV, TS, M2TS, F4V, DAT, M4V, TRP, WebM, MPG, MPEG, MTS
Supported Audio Formats
MP3, WMA, WAV, AC3, AAC, Ogg Vorbis, AIFF, AMR, M4A
Supported Pictures Formats
BMP, JPG, GIF
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
HDMI , VGA input , DVI-D input , Component video input , Audio line-in , Composite video input , Audio line-in , Network , Serial output , USB , Audio line-out , Serial input , Remote control input , Remote control output
Batteries
Serial cable , VGA cable
UL, C-Tick, BSMI, GOST, cUL, CCC, CECP, EPA
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
AC 120/230 V
Power Consumption Stand by
0.5 Watt
Smart power
Limited warranty - 3 years
5 °C
20 - 80%
Accessories
£7.58
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£21.64
£41.53
£56.29
£17.48
Scroll to top
