BT.com
Wishlist
Philips BDL3260EL 32" 1920x1080  25ms VGA DVI HDMI DP LED LFD
Philips BDL3260EL 32" 1920x1080...
£632.18
Hurry, only 2 left in stock!
£632.18
Add to wishlist
Delivery
Standard 1-3 working days
With this energy efficient Signage Solution display, you will enjoy all the benefits of state-of-the-art connectivity and content management possibilities while being ensured that remote management safeguards the lowest cost of ownership.
Philips Signage Solutions E-Line BDL3260EL 32" Class (31.55" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
32"
Diagonal Size
31.55 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Video Wall Components Qty
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Digital signage, HTML5 support
Settings Cloning Capability
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
AC 100/230 V (50/60 Hz)
48.57 Watt
75.02 cm x 6.9 cm x 44.46 cm
11.4 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
48.57 Watt
Diagonal Class
32"
Diagonal Size
31.55 in
Commercial Use
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
100
75.02 cm
6.9 cm
44.46 cm
11.4 kg
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Colour Depth
16.7 million colours
Image Contrast Ratio
1300:1
Dynamic Contrast Ratio
500000:1
Brightness
400 cd/m²
Widescreen Modes
16:9
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.36 x 0.36mm
Pull Down Compensation
3:2, 2:2
Response Time
25 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
Backlight Life
60,000 hour(s)
Comb Filter
3D digital
Commercial Features
Dynamic Contrast, 3D MA deinterlacing, Smart Insert, Smart Control, Motion Compensation, SmartCMS
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
100 x 100 mm, 400 x 200 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Media Player
Supported Video Formats
MPEG-4, WMV, MKV, VOB, TS, M2TS, M4V, MPG, MPEG, MTS
Supported Audio Formats
MP3, WMA, WAV, AAC, AIFF, LPCM, M4A
Supported Pictures Formats
BMP, JPG, GIF
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Functionality
WEB browsing
LAN
DLNA
Connector Type
DisplayPort input , 2 x HDMI input , DVI-D input , VGA input , USB , Component video input , Composite video input , DisplayPort output , DVI-I , VGA output , Audio line-in , Audio line-in , Audio line-out , Speakers output , Network , Serial , Remote control
Batteries
VGA cable , Serial cable
FCC Class B certified, UL, VCCI, C-Tick, BSMI, GOST, cUL, CB, CCC, RoHS, PSE Mark, J-MOSS
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.3 Watt
Smart power
Limited warranty - 3 years
20 - 80%
Accessories
£7.63
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£21.84
£41.94
£56.80
Scroll to top
