BT.com
Wishlist
Philips 55" 1920x1080 5ms VGA DVI HDMI USB LED LFD
Philips 55" 1920x1080 5ms VGA DVI...
£986.82
34 in stock
£986.82
Add to wishlist
Delivery
Standard 1-3 working days
Deliver startlingly clear images in a more eco-friendly way. High on performance and reliability, yet low on power consumption, it is ideal for projects where no compromise is accepted.
LED-backlit LCD flat panel display
141 Watt
Diagonal Class
55"
Diagonal Size
54.6 in
Commercial Use
Yes - digital signage
Series
Q-Line
TV Tuner
No tuner
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
Picture Enhancements
Pixel Shift
Video Wall Components Qty
225
Dimensions
Without stand
123.86 cm
5.99 cm
71.11 cm
16 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LCD Backlight Technology
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
1200:1
Dynamic Contrast Ratio
500000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.63 x 0.63mm
Response Time
6.5 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish
Backlight Life
50,000 hour(s)
Commercial Features
HTML5 support, Clinical D-image
Smart Control, SmartCMS, One Wire, Smart Collection
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm, 400 x 400 mm
DVR
DVR
Flash - 8 GB
Video Features
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Media Player
Supported Video Formats
MPEG-4, Xvid, DivX, WMV, ASF, QuickTime, AVI, MKV, MOV, VOB, FLV, TS, M2TS, F4V, DAT, M4V, TRP, WebM, MPG, MPEG, MTS
Supported Audio Formats
MP3, WMA, WAV, AC3, AAC, Ogg Vorbis, AIFF, AMR, M4A
Supported Pictures Formats
BMP, JPG, GIF
USB Port
USB Ports Qty
1
Storage Drive Capacity
8 GB
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
HDMI , VGA input , DVI-D input , Component video input , Audio line-in , Composite video input , Audio line-in , Network , Serial output , USB , Audio line-out , Serial input , Remote control input , Remote control output
Batteries
Serial cable , VGA cable
UL, C-Tick, BSMI, GOST, cUL, CCC, CECP, EPA
Environmental Standards
ENERGY STAR Qualified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
AC 120/230 V
Power Consumption Stand by
0.5 Watt
Smart power
Limited warranty - 3 years
5 °C
20 - 80%
Accessories
£7.23
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£21.40
£39.28
£52.56
£17.48
Scroll to top
