BT.com
Wishlist
Philips 28" LCD Monitor LED Backlight 1920 x 108016:9 Black Bezel
Delivery
Standard Due date unavailable
This big, attractive Philips display with slim bezel and MVA screen gives you awesome, vibrant color images. Mobile HD link allows you to mirror your smartphone, immersing you in powerful multimedia.
Philips E-line 284E5QHAD - LED monitor - Full HD (1080p) - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class B
Energy Consumption per Year
57 kWh
Power Consumption (On mode)
39 W
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.323 mm
Brightness
300 cd/m²
Contrast Ratio
20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Input Connectors
2xHDMI, VGA
Display Position Adjustments
Tilt
Glossy cherry
5.54 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Display Type
Energy Class
Class B
57 kWh
39 W
Diagonal Size
28"
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.323 mm
Brightness
300 cd/m²
Contrast Ratio
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
176
Vertical Viewing Angle
176
Backlight Technology
WLED
SmartContrast, Mobile High-Definition Link (MHL)
Glossy cherry
- with stand
5.54 kg
Audio
Speakers
VGA , 2 x HDMI , Headphones
Mechanical
Tilt
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
1 x VGA cable , 1 x audio cable
Power Supply
External
23.18 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Included Software
Philips SmartControl Lite
Dimensions & Weight Details
With stand - weight: 5.54 kg
ENERGY STAR Certified
Limited warranty - 3 years
Accessories
£9.99
£6.91
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.84
£36.18
£49.00
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.62
Scroll to top
