BT.com
Wishlist
Philips 276E6ADSS/00 27" 1920x1080 DVI VGA HDMI Monitor
Delivery
Standard Due date unavailable
Colors like you've never seen before. Philips E-line monitor features Color IQ Quantum Dot technology, an advanced nano-technology that produces the richest and most vivid colors.
Philips E-line 276E6ADSS - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
66 kWh
Power Consumption (On mode)
45 W
Panel Type
ADS-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
14 ms (typical); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, HDMI (MHL)
Display Position Adjustments
Tilt
Glossy silver
64 cm x 23.5 cm x 47.1 cm
5.33 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, CEL, TCO Displays, cETLus
Display Type
Energy Class
Class C
66 kWh
45 W
Diagonal Size
27"
Panel Type
ADS-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, SmartImage Lite, SmartResponse, SmartContrast, WideView, Touch Control, 100% sRGB colour gamut, 99% Adobe RGB colour gamut, SmartControl Lite, Mercury free
Glossy silver
64 cm x 23.5 cm x 47.1 cm - with stand
5.33 kg
VGA , DVI-D (HDCP) , MHL / HDMI (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+20
MTBF
50,000 hour(s)
25.89 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7 / Windows 8
Dimensions & Weight Details
With stand - width: 64 cm - depth: 23.5 cm - height: 47.1 cm - weight: 5.33 kg , Without stand - width: 64 cm - depth: 4.8 cm - height: 39 cm - weight: 4.57 kg
ENERGY STAR Certified
20 - 80%
Accessories
£7.96
£8.85
£12.16
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£9.90
£6.00
C2G USB to DVI Adapter Up To 2048 x 1152
Quicklinx: 8H1Y | In Stock
£41.59
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.38
£56.05
Scroll to top
