BT.com
Wishlist
Philips 275C5QHAW/00 27" 1920x1080 VGA HDMI Monitor
Delivery
Standard Due date unavailable
The Philips Moda 2 combines stunning visuals with the convenience of a Bluetooth speaker system in one refined package. Easily stream your music and take calls from the powerful Bluetooth speaker system, to expand your experience.
Philips Brilliance C-line 275C5QHAW - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
24 W
Microphone
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
14 ms (typical); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Glossy white
61.3 cm x 23.8 cm x 46.7 cm
5.67 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, BSMI, GOST, SASO, SEMKO, CCC, DDC/CI, RoHS, Lead-Free, WEEE, TCO Displays 6.0, cETLus, ISO9241-307
Display Type
Energy Class
Class A+
34 kWh
24 W
Diagonal Size
27"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, power off timer, sRGB colour management, HDCP, SmartContrast, SmartImage, power on timer, Incredible Surround, SRS WOW HD, Flicker Free technology, Mercury free
Glossy white
61.3 cm x 23.8 cm x 46.7 cm - with stand
5.67 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
7 Watt
Input
Microphone
VGA , 2 x HDMI , Microphone , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
Security lock slot (cable lock sold separately), Stereo Bluetooth Wireless Technology, 360° Flip Design
MTBF
30,000 hour(s)
Power Supply
External
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7 / Windows 8
Dimensions & Weight Details
With stand - width: 61.3 cm - depth: 23.8 cm - height: 46.7 cm - weight: 5.67 kg , Without stand - width: 61.3 cm - depth: 4.2 cm - height: 37.2 cm
ENERGY STAR Certified
20 - 80%
Accessories
C2G 2M HD15 M/M UXGA MONITOR CBL W/ FE
Quicklinx: 63P0 | In Stock
£9.56
£10.42
£13.38
C2G VGA to Composite PC-TV Video Adapter
Quicklinx: 7CC5 | In Stock
£35.89
Scroll to top
