BT.com
Wishlist
Philips 273P3 27" 1920x1080 VGA DVI HDMI LED Monitor with Speakers
Delivery
Standard 1-3 working days
Eco-friendly, EPEAT Gold certified Philips Professional 273P3 LED display with intelligent PowerSensor detects user presence and adjusts power consumption saving up to 80% of energy bills!
Philips P-line 273P3LPHEB - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
55 kWh
Power Consumption (On mode)
38 W
USB 2.0 hub
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1200:1 / 20000000:1 (dynamic)
Response Time
3.5 ms (typical); 1 ms (gray-to-gray)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Carbonite black
64.2 cm x 24.4 cm x 52.8 cm
8.7 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE
3 years warranty
Display Type
Energy Class
Class B
55 kWh
38 W
Diagonal Size
27"
Built-in Devices
USB 2.0 hub
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
170
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
Sync on Green, sRGB colour management, HDCP, PowerSensor, SmartResponse, SmartContrast, SmartImage, Touch Control
Carbonite black
64.2 cm x 24.4 cm x 52.8 cm - with stand
8.7 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D , HDMI , 3 x USB 2.0 downstream , Audio line-in , Headphones , USB 2.0 upstream (Type B)
Mechanical
Tilt Angle
25
Swivel Angle
130
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
MTBF
30,000 hour(s)
Power Supply
Internal
16.7 Watt
Power Consumption Stand by / Sleep
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 64.2 cm - depth: 24.4 cm - height: 52.8 cm - weight: 8.7 kg , Without stand - width: 64.2 cm - depth: 6.5 cm - height: 39.1 cm - weight: 6.4 kg
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
Accessories
£9.99
£6.94
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.78
£36.49
£49.42
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£56.07
Scroll to top
