BT.com
Wishlist
Philips 272P4APJKHB/00 27" 2560x1440 VGA DVI HDMI Monitor
Delivery
Standard Due date unavailable
Get the perfect results you're looking for. This professional IPS-AHVA display delivers CrystalClear Quad HD images. PerfectKolor Technology ensures factory-calibrated 99% AdobeRGB color space and a billion colors for perfect results.
Philips Brilliance P-line 272P4APJKHB - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
76 kWh
Power Consumption (On mode)
52 W
2.0 megapixel camera
Panel Type
AHVA
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
12 ms (typical); 5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, DVI-D, DisplayPort
Speakers
Integrated
Display Position Adjustments
Textured black
63.9 cm x 24.2 cm x 58 cm
7.5 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, TCO Certified Edge, TCO Displays 6.0, cETLus, CU-EAC
Display Type
Energy Class
Class C
76 kWh
52 W
Diagonal Size
27"
Built-in Devices
Panel Type
AHVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Chinese (traditional), Chinese (simplified), Ukrainian, English, German, French, Italian, Portuguese, Polish, Swedish, Russian, Spanish, Turkish, Japanese, Korean
Picture in picture, Sync on Green, sRGB colour management, SmartResponse, MultiView, SmartContrast, SmartImage, 99% Adobe RGB colour gamut, Smart Ergo base, Crystal Clear Quad HD, Flicker Free technology, Mercury free, PBP, PerfectKolor technology, SmartUniformity
Textured black
63.9 cm x 24.2 cm x 58 cm - with stand
7.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
3 x USB 3.0 , DVI-D (HDCP) , DisplayPort , 2 x HDMI , Headphones , Audio line-in
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
External
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Included Software
Philips SmartControl Premium
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1
Dimensions & Weight Details
With stand - width: 63.9 cm - depth: 24.2 cm - height: 58 cm - weight: 7.5 kg , Without stand - width: 63.9 cm - depth: 6.4 cm - height: 40.5 cm - weight: 5.1 kg
ENERGY STAR Certified
20 - 80%
Accessories
£8.85
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£39.98
£24.58
£9.80
£18.00
£13.78
Scroll to top
