BT.com
Wishlist
Philips 272G5DYEB/00 27" 1920x1080 Display Port HDMI Monitor
Delivery
Standard Due date unavailable
Dominate the competition like never before. The Philips 27" 272G5DYEB gaming monitor with NVIDIA G-sync technology eliminates tearing and stuttering providing the smoothest and fastest gaming experience ever.
Philips Brilliance G-line 272G5DYEB - 3D LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
3D Capable
Adaptive-Sync Technology
NVIDIA G-SYNC
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 144 Hz
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (typical); 1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DisplayPort
Display Position Adjustments
Textured black
63.9 cm x 24.2 cm x 58 cm
7.8 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, BSMI, GOST, SASO, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE, TCO Displays 6.0, cETLus
Display Type
Diagonal Size
27"
3D Capable
NVIDIA G-SYNC
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Vertical Refresh Rate
30 - 150 Hz
Horizontal Refresh Rate
30 - 160 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
sRGB colour management, SmartResponse, Smart Ergo base, nVidia 3D Vision
Textured black
63.9 cm x 24.2 cm x 58 cm - with stand
7.8 kg
DisplayPort , 4 x USB 3.0
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
MTBF
30,000 hour(s)
Power Supply
Internal
27.5 Watt
Power Consumption Stand by
0.5 Watt
Microsoft Windows 7, Windows 8
Dimensions & Weight Details
Without stand - width: 63.9 cm - depth: 6.4 cm - height: 40.5 cm - weight: 5 kg , With stand - width: 63.9 cm - depth: 24.2 cm - height: 58 cm - weight: 7.8 kg
ENERGY STAR Certified
20 - 80%
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£40.57
£24.94
£9.80
£18.27
£14.01
Scroll to top
